Coco TRS-80 Emulator
Postby Maxrom » Sat May 14, 2011 1:23 pm
What is the emulator that will work on Win 7 .....I'm new to this.....
I have downloaded "Dallas Quest" Old memories...
But how I run the game?...I search for emulator for
Tandy TRS-80 Coco 1 ...But no luck
Any Help will be appreciated!!
Thank You "The Old Computer"
:thankyou:
Removed identical post from Retro Consoles. This is the best place to post for emulator help. No need to double post in different threads.
Maxrom
Fav System: CoCo 1 Tandy
Re: Coco TRS-80 Emulator
Postby te_lanus » Sat May 14, 2011 3:00 pm
Hi you can use mess's coco2 emulation. you can get it here: http://mess.redump.net/downloads
Postby Maxrom » Sat May 14, 2011 6:29 pm
Thank's allot....I will try that and give you some news... :)
Have a great day!!
Maxrom
Postby Maxrom » Sat May 14, 2011 6:38 pm
Can not open .DSK files :(
Maxrom
Postby te_lanus » Sat May 14, 2011 7:35 pm
Option 1
In MESSui, select the Color Computer 2. Then select Device View. Then on the first floppy disk line there is a (...) button, press it and select mount.then select the *.dsk or zip. then double click on coco computer 2 name. it should start the emulation, then you load like a normal coco.
Option 2:
Get QMC2 from here: http://qmc2.arcadehits.net/Win32/ (get SVN2754, my instruction is based on the zip version<but there is no difference between the versions> ) extract it somewhere. start qmc2-mess. select your mess executable, rom/bios dir, and hash dir.
Here is a screenshot with markings to explain what to do. the numbers and letters in ()reference to the screenshot. Your's should look a bit different as I removed a few tabs and moved the device selector around.
select the color computer 2 (* on screenshot). go to device tab (A) then press on the button (labelled 1), it should open the device instance box. scroll down to floppydisk1 (B) and press Button (3). Select the game, and press the button (2). It should add a entry in available Device Configurations with the games name. Double click on the games name to start the game.
Loading the game:
dir 0
Basic game:
run"0:*.bas"
Machine coded game:
loadm"0:*.bin":exec
PS the coco2 zip is the Bios that MESS Need
coco2.zip
(21.18 KiB) Downloaded 434 times
Postby Maxrom » Sun May 15, 2011 3:00 pm
Thank's allot it work :)
Maxrom
Postby Robin Milford » Sun Jun 19, 2011 9:55 pm
Hey I cant play dallas quest in windows 7 64 Bit. Is there any way or emulator to play the game? :?:
Robin Milford
Fav System: Windows 7
