PS1 emulator problems
Re: PS1 emulator problems
Postby te_lanus » Sat Apr 30, 2011 9:06 am
Hi phantom, try to load the cue file and see if it works, if not report back as there might be one solution but I'll have to investigate first
Postby gamfrkI » Sat Apr 30, 2011 9:23 am
can you post what setting you have it on?
Postby phantom309 » Sat Apr 30, 2011 10:23 am
@ te_lanus - Tried to load .cue file and error occurred "CD not usable: Failed to open file"
@gamfrk - Which setting and/or emulator are you referring to? Im assuming the latter(psx) but not sure since i mentioned issues with both psx and epsxe.
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." - Thomas Jefferson
phantom309
Next LVL Up at : 15
Next LVL Up at : 15
Fav System: PS1-3,Nes,SNES
Postby te_lanus » Sat Apr 30, 2011 11:20 am
Hi phantom I've got the same problem with Dino Crisis (USA) (v1.1)
it comes with a cue and two iso's. here is a how-to:
converting a multi-part (multiple bin/iso games with one cue sheet (thus one CD many parts) into a CD usable by PSX emu
Tools needed:
Daemon tools.
Isobuster.
1. Load the cue with daemon tools into a virtual drive. (you could tell epsxe that it use the virtual drive as a cd drive and it should also work)
2. after loading the cd into the virtual cd, start isobuster, select the virtual CD. right click on (you'll see it says cd at the top under the dropdown list) CD and highlight extract CD <image> then select raw (Bin, ISO). Save the CD to a directory of your choice
3. start epsxe and select created iso.
you should be able to play without problems
Postby phantom309 » Sun May 01, 2011 3:17 am
OK,sounds good.
When I get a chance to download the programs and test it out Ill post and let you know how it turned out.
Thanks again.
phantom309
Next LVL Up at : 15
Next LVL Up at : 15
Postby gamfrkI » Sun May 01, 2011 4:38 am
phantom309 wrote:@gamfrk - Which setting and/or emulator are you referring to? Im assuming the latter(psx) but not sure since i mentioned issues with both psx and epsxe.
epsxe settings so i can try those settings on my epsxe
Previous
