How to reset wireless cisco router password ?
Postby Sophiawood » Mon Nov 25, 2013 10:15 am
I forgot my cisco router's password and this problem bothers me for a long time. I want to find an easy way to reset password. Any thoughts ?
Sophiawood
Fav System: ios
Re: How to reset wireless cisco router password ?
Postby SE7EN » Mon Nov 25, 2013 10:18 pm
Sophiawood wrote:I forgot my cisco router's password and this problem bothers me for a long time. I want to find an easy way to reset password. Any thoughts ?
well.. you can either search on Google for the default password if you never changed it; or you can take a small object, like a safety pin, and press it into the 'reset' button hole that is commonly found on the back of most routers for ~10 seconds.
Users browsing this forum: No registered users and 42 guests
