Horror House ROM help
Postby Tilren » Fri Nov 20, 2026 5:54 pm
Hello, I need some help running this ROM file of Nihon Falcom's Horror House. I got the file from this site on this page: https://www.theoldcomputer.com/roms/get ... AwMQ%3D%3D
I've tried various programs like WinRAR and 7z but I can never get the file to open (it doesn't work on PC88 emulators I've tried like M88 or QUASI88 either. I try loading it and nothing happens). Looking up how to open 7z.001 files, I've read that .001 files can't be opened on their own and should be with other files like .002, but there's only one file on the page.
Can someone help me run this file? Thank you.
Tilren
Re: Horror House ROM help
Postby Hot Trout » Sun Nov 22, 2026 5:05 pm
I tested it, download locally and then opened it with WinRAR. It opened ok for me and there is a T88 tape image inside which was all ok. I am not sure why it will not open for you. Try deleting it and downloading again. The version on the website appears to be fully working.
Hope this helps you out a bit.
HT
Postby Tilren » Tue Nov 24, 2026 12:49 am
Hot Trout wrote:I tested it, download locally and then opened it with WinRAR. It opened ok for me and there is a T88 tape image inside which was all ok. I am not sure why it will not open for you. Try deleting it and downloading again. The version on the website appears to be fully working.
Hi, and thank you. I was able to get to the t88 file, but nothing seems to run it. When I try opening it in M88, nothing happened (I tried all the modes like N88/N80 and V1/V2) and Quasi88 won't find it in its file selection when I'm in the correct folder. What program did you use to run the game?
(I'm on a Lenovo Legion laptop with Windows 11 in case that helps).
Thanks again,
Tilren
Tilren
Postby Hot Trout » Tue Nov 24, 2026 1:22 pm
I would suggest using
https://github.com/bubio/QUASI88
for this file. Try it and let me know how you get on.
Users browsing this forum: No registered users and 202 guests
