Audio not working right N64
Postby fluuc33 » Wed Mar 09, 2011 3:26 pm
New to Emulators and and have downloaded some roms EX: Star Wars(Shadows of the Empire), Mortal Kombat 4, and the Audio skips and is sporadic. Can anyone please help. Thanks
fluuc33
Fav System: nes
Re: Audio not working right N64
Postby Guest » Sat Mar 19, 2011 9:51 pm
Can you please let us know what emulator you are using?
Personally, I have always thought that N64 emulation is sketchy and hard to get right. Wii does it poorly, Xbox is alot better but has some issues, Computer is just a pain without a real controller to work with. Sigh
Postby luke83 » Sun Mar 20, 2011 12:31 am
First , let us know what emulator your using , personally i prefer Project 64 as i have never had any problems with this as i have used it on many computers over many years.
You may also find in the set-up options different sound drivers , if you use a different codec it may give a good result on your PC.
Also are all the games doing the same thing? you may have a bad ROM .
Also are what are your PC stats? do you have enough power to run the emulator at full speed ?
i use my Nintendo 64 controllers on my computer , i have a $10 n64/PSx to USB converter that works great i use it for all my emulations :)
Here is a link to look at it , this is an Australian site however i am sure you could find one in what ever country you live in.
http://www.consolemate.com.au/playstati ... p-471.html
luke83
Has thanked: 17 times
Been thanked: 30 times
Users browsing this forum: No registered users and 57 guests
