VisualBoy Advance Help needed
Postby RawrTynne » Mon Jan 17, 2011 2:55 am
So im playing the MMNT6 (Megaman NetworkTransmission 6) on the VBA, but every so often the game becomes slow and laggy. Is this normal for the VBA? im kinda upset because theres a LOT of things on the game that requires smooth gameplay and well its impossible to play when it becomes laggy.
RawrTynne
Fav System: GBA
Re: VisualBoy Advance Help needed
Postby Kherr » Mon Jan 17, 2011 2:07 pm
I don't think so, I've been using VisualBoy Advance for a long time, and I've never had any issues, and I've got a shitty laptop ATM... I'll check it out. :3
Postby RawrTynne » Tue Jan 18, 2011 12:13 pm
Thanks in advanced if you find anything. Its been impossible to get past this part due to the inability to be precise Q_Q
RawrTynne
Fav System: GBA
Postby RawrTynne » Tue Jan 18, 2011 11:02 pm
Ah i have found my problem. Apparently under Video settings i didnt put frameskip on, so it was causing the lag
RawrTynne
Fav System: GBA
Postby Hot Trout » Tue Jan 18, 2011 11:29 pm
Good to know you got it working. Thanks for letting us know.
Postby Guest » Sat Jan 29, 2011 10:37 pm
Locked
