Using USB Controllers with Snes and NES Emulators for a Mac
Postby reqwiumuser » Sun Sep 26, 2010 6:28 pm
I just bought a nes and snes usb controller to play thru the snes and nes emulators and i am getting no response from the controller can anyone help me figure out how to get these controllers to work ? I'm using a mac g5.
thanks,
Will
reqwiumuser
Re: Using USB Controllers with Snes and NES Emulators for a
Postby JAHGoVeg » Sun Sep 26, 2010 7:55 pm
which emulator are you using?
Postby Guest » Mon Sep 27, 2010 4:15 am
reqwiumuser wrote:I just bought a nes and snes usb controller to play thru the snes and nes emulators and i am getting no response from the controller can anyone help me figure out how to get these controllers to work ? I'm using a mac g5.
thanks,
Will
I dont have a working MAC at the moment but my first guess would be to go into the settings of the emulator (everyone is different unless you tell us which one your using as JAHGoVeg mentioned) and then find the "input" section. It may be as simple as you have to select the input to be controller or gamepad. If its not that then you could try (in the same spot) to "map" the keys.
Meaning: There should be a spot that says:
A button =
B button =
Start =
etc...
and you go through all of them and change them to the correct button corresponding to the controller.
Let us know! Thanks
Postby gamfrkI » Mon Sep 27, 2010 4:18 am
is it mac compatible
