Can Emulators and Roms be run from an external hard drive?
Postby GAMESHARQ » Mon Oct 03, 2011 4:42 pm
Or do they need to be installed on my PC?
GAMESHARQ
Re: Can Emulators and Roms be run from an external hard driv
Postby gamfrkI » Mon Oct 03, 2011 4:59 pm
most emu's are portable so yes you can run it from an external hd
Postby te_lanus » Mon Oct 03, 2011 5:06 pm
If set-up correctly, yes it can be run from External HD
Postby GAMESHARQ » Mon Oct 03, 2011 5:35 pm
How do I set it up correctly?
GAMESHARQ
Postby gamfrkI » Tue Oct 04, 2011 2:49 am
for most emu's ive used (zsnes,epsxe,pj64 most used) all i had to do is make sure that they knew where the roms were
Postby Kherr » Wed Oct 05, 2011 3:27 pm
gamfrkI wrote:for most emu's ive used (zsnes,epsxe,pj64 most used) all i had to do is make sure that they knew where the roms were
Agreed. :3
Just unzip the emulator to the removable jump drive or to an external HDD and then put the roms you want to play into a folder marked "ROMS" on the device, then when you load up the program just tell it to find the roms in that folder on your device. It should work perfectly.
Postby stinow » Wed Jan 11, 2012 9:16 am
I'm curious if this performs well enough with, let's say, Hyperspin (FE).
For the love of some people I'll start making a portale Hyperspin setup when finished with the arcade cabinet.
It will hold a complete 'ready-to-go' Hyperspin, emulators, daemontools, (possibly roms) & batchfiles.
Will take some time though, and if anyone here is interested in having one, just PM me.
Cheers guys :)
Users browsing this forum: No registered users and 61 guests
