Radio Shack Model 1, load game: ?L3 ERROR
Postby Roman78 » Thu Jun 16, 2011 12:41 pm
I'm trying to load a basic game i downloaded from this site. I'm running the Radio Shack Model 1 emulator from Jeff Vavasour.
I did the following:
Made a disk whit vfromat, copied the .bas file into the disk image using vwrite. Than in the emulator i pressed F2 and changed the Drive 0 to the name of the disk image file (filename is DISK1.DSK).
But than in the emulator i tried LOAD "OWLTREE1.BAS" and i receive a ?L3 error. Also the command FILES give an error: ?SN ERROR.
The problem is i'm unable to search ?L3 or ?SN ERROR because every search engine removes the Question mark, and this leaves me whit L3 and SN Error.
For me it's 20 years ago i using this OS.
Roman78
Been thanked: 37 times
Re: Radio Shack Model 1, load game: ?L3 ERROR
Postby Roman78 » Fri Jun 17, 2011 9:16 am
I found the solution and it's working. Solution found on this site: http://www.trs-80.com/wordpress/importi ... -emulator/
Roman78
Postby Hot Trout » Fri Jun 17, 2011 10:01 am
I have given you some thanks for a terrific link to a great site and also for taking the time to come back and post your findings. Your input is much appreciated. :thumbup:
Users browsing this forum: No registered users and 61 guests
