PCSX2 - Playstation 2 Emulator help
Postby Treyla10 » Sun Jun 05, 2011 2:30 pm
ok i finally got my playstation 1 emulator good to go, but now I have a PS2 and i love the hell out of my star wars battlefront 1, but the cd is getting old. What links, BIOS, etc do I need to get this one working? Also is this PS2 emulator good or is there one that is a bit more recommended? Keep in mind that like me, this thread, is for idiots , who dont know much and may need step by step instructions. Thank you yet again. =o)
:freakout: :clap: :wtf: :typing: :headbang:
Treyla10
Next LVL Up at : 25
Next LVL Up at : 25
Fav System: 1:NES 2:PS 3:PS2
Re: PCSX2 - Playstation 2 Emulator help
Postby gamfrkI » Sun Jun 05, 2011 9:39 pm
first you will need to meet these requirements
Minimum
    Windows XP/Windows Vista or Linux 32bit/64bit
    CPU that supports SSE2 (Pentium 4 and up, Athlon64 and up)
    GPU that supports Pixel Shader 2.0
    512MB RAM
Recommended (Will run 50-60fps)
    Windows 7 or Linux 32bit/64bit
    CPU: Core 2 Duo 3.2 GHz or Core-i series
    GPU: GeForce 8600 GT or better
    1GB RAM (2GB if using Windows Vista or Windows 7)
Postby Treyla10 » Mon Jun 06, 2011 1:17 am
i have that i just need to know what add ons i need to put in it and which ps2 emulator is the best like for my ps1 i had to find and install a BIOS in it.
Treyla10
Next LVL Up at : 25
Next LVL Up at : 25
Postby gamfrkI » Mon Jun 06, 2011 1:43 am
pcsx2 is the same you need bios
the latest version here
and a guide here
Postby Treyla10 » Mon Jun 06, 2011 4:56 pm
i cant find a good BIOS site any ideas where i can get one? I tried the ones from this site:
http://www.theoldcomputer.com/roms/inde ... -Boot/Sony
but when i went to extract it said the folders were empty, and when i tried to double click them it said the folder was invalid or corrupt.
Treyla10
Next LVL Up at : 25
Next LVL Up at : 25
Postby gamfrkI » Mon Jun 06, 2011 6:17 pm
bios here
Postby Treyla10 » Mon Jun 06, 2011 8:15 pm
that file is broken i went to unzip with both my extract program and 7zip and both times it said error reading file. but there is a file in it it just wont let me unzip it into the pcsx2 bios folder.
Treyla10
Next LVL Up at : 25
Next LVL Up at : 25
Postby Treyla10 » Mon Jun 06, 2011 8:22 pm
ok had to reboot the computer apparently but now i ran into a real dilemma from what im seeing there is no site for ps2 roms. i have the pcsx2 0.9.8 screen up but without a way to find and play a rom dont know if it works or not. why does everything have to be so difficult lolz.
Treyla10
Next LVL Up at : 25
Next LVL Up at : 25
Postby gamfrkI » Mon Jun 06, 2011 8:24 pm
if you have a ps2 disc you can use that
Postby Treyla10 » Mon Jun 06, 2011 8:59 pm
ok i have the CD in there but the emulator tells me:
Error : File Not found
I've tried running the .elf file as well as going thru it and trying diff .iso related files. How do I get this emulator to recognize the cd? it brings up a second screen though thats all black.
Treyla10
Next LVL Up at : 25
Next LVL Up at : 25
Users browsing this forum: No registered users and 61 guests
