Emulation on Linux
Emulation on Linux
Postby Akira_98 » Sun Apr 10, 2011 12:05 pm
Hey there. I've been wondering, are there any Linux-compatible emulators out there? Windows is quite broken on my laptop, so I usually run Ubuntu on it. I've seen a few emulators labeled as Linux-compatible, but I was looking for recommendations by more experienced users. The less programs I have to run under Wine, the better. :D
Akira_98
Re: Emulation on Linux
Postby crustyasp46 » Sun Apr 10, 2011 4:34 pm
H ave you tried to link to the emulator section. There are numerous Linux emulators listed. Which is the best, I can not help you on that, but there may be others who can. Hope you find what you are looking for.
Wlcome to TOC. :welcome:
Postby Guest » Sun Apr 10, 2011 9:02 pm
It depends on which system you are looking to emulate.
SNES: ZSNES
NES: FCEUX
Gameboy Series: VisualBoyAdvance
PSX: pSX
Those are the ones that I deal with normally. Others in our community play a further range of systems that I do so they will have better input
Hope that helps
Postby Akira_98 » Sun Apr 10, 2011 9:51 pm
Those are what I would normally use, but I was under the assumption most of those wouldn't work on Linux. Turns out all my preferred emulators will. I probably should have known that. :oops:
Thanks for your help!
Akira_98
Postby Guest » Sun Apr 10, 2011 9:54 pm
No problem. Most of the best emulators tend to be cross compatible for the OSes because of demand. Which is nice
Postby luke83 » Mon Apr 11, 2011 12:11 am
SNES: ZSNES
NES: FCEUX
PSX: pSX
Gens : Sega megadrive , sega cd
Pcsx : Also PSX
Yabuse : Sega saturn
Mupen : N64
DOsbox : Dos ( i use DBGL ( dos box game launcher ) as my front end for dosbox)
Who needs windows :tongue:
luke83
Has thanked: 17 times
Been thanked: 30 times
Postby JAHGoVeg » Tue Apr 12, 2011 4:53 am
i feel like crap now.... i was supposed to get emulator .RPM's and .DEB's .... I REALLY feel like crap
Postby Guest » Tue Apr 12, 2011 5:48 am
Nah its all good.
