registered but still considered as guest...
Postby ahahahaah » Sat Dec 03, 2022 7:01 pm
hello
i've just registered and in this forum i can login (i'm typing this with my account), but in this page https://www.theoldcomputer.com/roms/getfile.php?file=Li9Db21tb2RvcmUvQW1pZ2EvV0hETG9hZC9HYW1lcy1XSERMb2FkL0FsYWRkaW5fdjEuNV9BR0FfMDQyMC56aXA=
i have the status "guest"
if i type my login and username in the download page, it is said that login or password is not correct
is it a bug or is there something i have not done correctly?
how can i login in this forum page and not in the download page?
thanks
ahahahaah
Re: registered but still considered as guest...
Postby Hot Trout » Mon Dec 05, 2022 10:56 am
ahahahaah wrote:hello
thanks
It may also be possible that your password contains symbols or characters that are not being recoganised. Please change your password to something strong that has capitals, numbers and more basic symbols like / - # £ etc
Next LVL Up at : 3650
Has thanked: 2233 times
Been thanked: 1954 times
Postby ahahahaah » Mon Dec 05, 2022 4:18 pm
thanks
the symbol used is "&" and it is recognised since i can login with it in the forum (and i can write this post because i am connected).
if i load and refresh the rom page i am a guest and my login/password are not accepted.
see screenshot
ahahahaah
Postby Hot Trout » Wed Dec 07, 2022 9:45 am
I suggest changing your password anyway, just to see if that works.
Postby ahahahaah » Wed Dec 07, 2022 3:09 pm
it is done with a password that has only letters and numbers
now it works, so there was a problem with the "&" character
now the problem i have is that the archive doesn't contain .adf file.
usually amiga files have adf extensions. if i rename the disk.1 in disk.adf it doesnt work
ahahahaah
Postby Hot Trout » Thu Dec 08, 2022 4:51 pm
ahahahaah wrote:it is done with a password that has only letters and numbers
There are several Amiga sections including a complete ADF collection. Go to this link to download them. If they are in ZIP format remember to decompact them 1st.
https://www.theoldcomputer.com/roms/ind ... dore/Amiga
Postby ahahahaah » Thu Dec 08, 2022 11:39 pm
yes i was talking about the file/rom i linked at the beginning of this topic.
when i decompress it, i find different files but none of them has an adf extension.
ahahahaah
Postby Hot Trout » Fri Dec 09, 2022 2:32 pm
ahahahaah wrote:yes i was talking about the file/rom i linked at the beginning of this topic.
Sorry, I went and downloaded that file and I extracted the ZIP to a LHA file. This is a pain but the LHA file extension is also a compressed file which you will need to open again in order to extract all the file within. If you are using ZIP or similar, just choose to open it again using the same zip utility and it should open up.
Postby ahahahaah » Fri Dec 09, 2022 6:29 pm
Hot Trout wrote:Sorry, I went and downloaded that file and I extracted the ZIP to a LHA file.
and you have found adf files inside the LHA? :shock:
Hot Trout wrote:This is a pain but the LHA file extension is also a compressed file which you will need to open again in order to extract all the file within. If you are using ZIP or similar, just choose to open it again using the same zip utility and it should open up.
i have not told it at the beginning but yes, it was what i have done. when i said that i decompressed it, i have also decompressed the LHA
but i have not found adf files inside.
ahahahaah
Postby Hot Trout » Fri Dec 09, 2022 11:37 pm
The images inside that particular download are for WHDLoad, you most likely got them from that section of the Amiga Roms. Try looking at these various versions of Aladdin.
https://www.theoldcomputer.com/roms/ind ... iga/Games/[ADF]/a
