Problem in installing android jellybean
Postby Digons » Mon Jul 15, 2013 8:02 pm
hello guys..
i have android 4.0.4 version on my htc 1x..but i am unable to install android version 4.1 jelly bean..it gives some kind of error saying "zip file is missing from sdcard"...can anyone help?
i have tried many times..update is available but i am unable to install it..help??
Regards
Digons
Re: Problem in installing android jellybean
Postby Dragon Mech » Sat Sep 07, 2019 9:06 am
ummm. check the post date Vera.
Has thanked: 570 times
Postby IamCarry » Fri Jun 03, 2022 6:41 am
RogerEye1253 wrote:
Digons wrote:hello guys..
i have tried many times..update is available but i am unable to install itFMWhatsapp APK.help??
Regards
You will need to install the latest version and you should also have compatible file version that fits your device.
I am also unable to install the latest vesion, I don't know what error is occuring. Can you suggest me any other solution.
IamCarry
