Computer Specs
Computer Specs
Postby Jesse » Tue Aug 10, 2010 5:00 pm
Post your main rig. Be as detailed or as general as you like.
MOTHERBOARD: Asus M3A79-T Deluxe
CPU: AMD Phenom Triple Core 8750 Black Edition (2.4 GHz)
RAM: 2 GB (2 sticks of 1 GB G-SKill RAM, dual channeled)
VIDEO: GeForce 8800 GTS 512 MB
POWER: 550W Rosewill
HARD DRIVE: 250 GB Seagate
DVDR: Plextor PX-880SA, 24X
CASE: Sunbeam Transformer ATX Full Tower
MONITOR: 22" Acer LCD, 1680x1050, 5ms
OS: Windows XP Pro SP3
I just got that (used) GeForce 8800 GTS 512 MB off of ebay. After installing it, I became interested in finding programs for monitoring heat, changing fan speed, etc... I'm pretty much a noob to tweaking my stuff. I got Speedfan, Core Temp, and EVGA Precision. Upon reading what the tools told me (and then checking the BIOS readings), my CPU was idling around 65c (which apparently is dancing near the danger zone)! I don't know how long it's been like that. The whole time? I've had this setup for like a year and a half. Now, upon lowering the voltage to the CPU (and reapplying thermal paste and re-seating the heat sink), it's idling around 45c. On full load for 2 hours with a stress test (Prime 95) it never crashed or went above 48c. So I guess it's fairly cool and stable now. Yay for that.
Anyway, the 8800 GTS seems to be doing it's job. It's slightly overclocked (it's that BFG OC edition) and is idling at 50c with 75% fan speed. I can now play Unreal Tournament 3 (the most graphically intensive game I own) at full settings on my native resolution (1680x1050) at a fairly constant 90 FPS (I capped it at 90 because apparently that's what it's capped at during online play anyway). Which is funny, because TF2 plays pretty much exactly the same as it did before (kinda shitty). Which I guess makes sense, since they say TF2 mostly relies on your CPU. But for me it seems like TF2 plays 2x or 3x worse than UT3. That's just f'd up and makes no sense at all. They need to fix TF2's performance issues.
ANYWAY, post you computer specs, if you feel like it.
Jesse
Re: Computer Specs
Postby Hot Trout » Tue Aug 10, 2010 7:29 pm
MOTHERBOARD : Gigabyte GA-P35T Bearlake P35
CPU : Intel Core 2Quad Q6600 @ 2.4GHz (OC to 3.2GHz)
RAM : 4 GB (4 sticks of 1 GB DDR3-1066) (OC to 1333MHz)
VIDEO : GeForce 8800 GTS 640 MB
POWER : 850W Thermaltake
HARD DRIVES : 1x68GB WD Raptor, 1x500GB WD Caviar Black, 2x1TB WD Caviar Green
DVDR : Pioneer DVD-RW Trayless
CASE : Cooler Master ATCS
MONITORS : 2 x Viewsonic VP201b 20.1" Professional Displays
Sound : Creative X-Fi Extreme Fidelity Audio Card
Additional : 3Com 3C2000-T Gigabyte NIC
OS : Windows XP Pro SP3
Its getting old now and I plan on a new i7 Rig sometime in the Autumn
Next LVL Up at : 3650
Has thanked: 2233 times
Been thanked: 1954 times
Re: Computer Specs
Postby Kherr » Wed Aug 11, 2010 2:27 pm
Cool computers dudes. I'm running a POS... >.>
Sony Corporation VAIO Model VGN-NR310E
MOTHERBOARD
Manufacturer: Sony Corporation
Model: VAIO
Chipset: Intel GL960 Rev. C0
Southbridge: Intel 82801HBM (ICH8-ME)
Bios Brand: Phoenix Technologies LTD
Bios Version: R1101J9 (10/23/2007)
CPU
Name: Intel Pentium T2370 (Codename Merom)
Package: Socket P (478)
Technology: 65 nm
Core VID: 1.250 V
Specification: Intel(R) Pentium(R) Dual CPU T2370 @ 1.73 GHz
Family: 6
Ext. Family: 6
Model: F
Ext. Model: F
Stepping: D
Revision: M0
Instructions: MMX, SSE (1,2,3,3S), EM64T
Core 0 and Core 1 Clocks for CPU catagory:
Core Speed: 1729.3 MHz
Multiplier: x13.0
Bus Speed: 133 MHz
Rated FSB: 532.1 MHz
Cache Data for both cores:
L1 Data: 2x32 KBytes 8-Way set associative, 64-Byte Line Size
L1 Inst.: 2x32 KBytes 8-Way set associative, 64-Byte Line Size
Level 2: 1024 KBytes 4-Way set associative, 64-Byte Line Size
Cores: 2
Threads: 2
RAM
Type: DDR2
Channels: Dual
DC Mode: Symmetric
Timings for RAM
DRAM Frequency: 266 MHz
(FSB:DRAM): 1:2
CAS# Latency (CL): 4.0 Clocks
RAS# to CAS# Delay (tRCD): 4 Clocks
RAS# Precharge (tRP): 4 Clocks
Cycle Time (tRAS): 12 Clocks
SPD for RAM Slot #1:
Type: DDR2
Module Size: 512 MBytes
Max Bandwidth: PC2-5300 (333 MHz)
Manufacturer: Nanya Technology
Part Number: NT512T64UH8B0FN-3C
Serial Number: 1C641B22
Correction: None
Week/Year: 07/08
SPD for RAM Slot #2:
Type: DDR2
Module Size: 1024 MBytes
Manufacturer: N/A
Part Number: SHTYGD2S648F124667
Serial Number: 00000001
Correction: None
Week/Year: N/A
Timings Table for Both RAM sticks:
JEDEC#1
Frequency: 200 MHz
CAS# Latency: 3.0
RAS# to CAS#: 3
RAS# Precharge: 3
tRAS: 9
tRC: 12
Voltage: 1.8 V
JEDEC#2
Frequency: 266 MHz
CAS# Latency: 4.0
RAS# to CAS#: 4
RAS# Precharge: 4
tRAS: 12
tRC: 16
Voltage: 1.8 V
JEDEC#3
Frequency: 333 MHz
CAS# Latency: 5.0
RAS# to CAS#: 5
RAS# Precharge: 5
tRAS: 15
tRC: 20
Voltage: 1.8 V
VIDEO
Mobile Intel(R) 965 Express Chipset Family
Revision: C
Memory Size: 256MBytes
(thats all CPU-ID gives me on that I'm afraid)
POWER
Unknown (No info given)
HARD DRIVE
Model: Hitachi HTS725032A9A364
Speed: 7200 RPM
Type: sATA
DISK DRIVE
OEM Sony VAIO DVD-RW Burner
(which, for some reason, doesn't read or burn DVD's... only CD's... makes a weird noise when trying to read DVD discs, which leads me to believe it's defective...)
SOUND
Realtek High Definition Audio
OS
Windows XP Professional Corporate Edition w/ SP3 & Linux Fedora Core 13 (Dual Boot)
And that's my baby. I got this lappy for 75 bucks... :p My old tower (Dell Dimension 2400) finally crapped out on me the other day... and it's a shame too because that was running a 256MB Nvidia card... T_T
Re: Computer Specs
Postby gamfrkI » Thu Aug 12, 2010 1:32 am
Operating System:Microsoft Windows XP Professional
OS Service Pack:Service Pack 3
DirectX:4.09.00.0904 (DirectX 9.0c)
Motherboard
CPU Type:Intel Pentium 4, 2600 MHz (26 x 100)
Motherboard Name:Intel Brownsville D845GBV / Brownsville 2 D845GEBV2 / Rexburg D845GRG / Rexburg 2 D845GERG2
Motherboard Chipset:Intel Brookdale-G i845GEV
System Memory:630 MB (DDR SDRAM)
BIOS Type:AMI (07/23/03)
Communication Port:Communications Port (COM1)
Communication Port:ECP Printer Port (LPT1)
Display
Video Adapter:Intel(R) 82845G/GL/GE/PE/GV Graphics Controller (64 MB)
3D Accelerator:Intel Extreme Graphics
Monitor:HP L1702 [17" LCD] (CNC42329L0)
Multimedia
Audio Adapter:Intel 82801DB ICH4 - AC'97 Audio Controller [B-0]
Storage
IDE Controller:Intel(R) 82801DB Ultra ATA Storage Controller - 24CB
Disk Drive:WDC WD400EB-11CPF0 (37 GB, IDE)
Optical Drive:HL-DT-ST CD-ROM GCR-8483B (48x CD-ROM)
Optical Drive:LITEON DVD-ROM LTD163D (16x/48x DVD-ROM)
SMART Hard Disks Status:OK
Partitions
C: (NTFS):38154 MB (14103 MB free)
Input
Keyboard Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse Microsoft PS/2 Mouse
Network
Network Adapter:Intel(R) PRO/100 VE Network Connection
Network Adapter:NETGEAR WG111v3 Wireless-G USB Adapter (192.168.1.69)
Modem:Intel(R) 537EP Data Fax Modem
Peripherals
USB1 Controller:Intel 82801DB ICH4 - USB Controller [B-0]
USB1 Controller:ntel 82801DB ICH4 - USB Controller [B-0]
USB2 Controller:Intel 82801DB ICH4 - Enhanced USB2 Controller [B-0]
USB Device:NETGEAR WG111v3 Wireless-G USB Adapter
i got it this comp years ago and i only updated the ram
Re: Computer Specs
Postby arinlares » Mon Aug 16, 2010 11:29 am
:? My emulation "workhorse" is my netbook ( Asus eee 1000ha) running ArchLinux, for it's vast availability of software (Games, emus, music stuffs). I could do emulation through Debian, but they don't have enough of the right software. Link to newegg.com, because I don't want to copy/paste/format: http://www.newegg.com/Product/Product.a ... 6834220440 (check the "Specifications" tab on the right of the page)
arinlares
Been thanked: 5 times
Re: Computer Specs
Postby Guest » Tue Nov 30, 2010 1:11 am
arinlares wrote::? My emulation "workhorse" is my netbook ( Asus eee 1000ha) running ArchLinux, for it's vast availability of software (Games, emus, music stuffs). I could do emulation through Debian, but they don't have enough of the right software. Link to newegg.com, because I don't want to copy/paste/format: http://www.newegg.com/Product/Product.a ... 6834220440 (check the "Specifications" tab on the right of the page)
I formated it for you =]
ASUS EPC1000HA-WHI001X
General
Brand - ASUS
Series - Eee PC
Model - EPC1000HA-WHI001X
Part# - 90OA0TB6C211131U11HQ
Color - Pearl White
Operating System
OS Provided - Windows XP Home
Processor
CPU Type - Intel Atom
CPU Speed - N270(1.60GHz)
CPU FSB - 533MHz
CPU L2 Cache - 512KB
Chipset
Chipset - Intel Mobile Chipset
Display
Screen Size - 10.0"
Widescreen Display - Yes
Display Type - WSVGA
Max Resolution - 1024 x 600
Display Feature - TFT
Graphics
Graphics Processor - Integrated Graphics
Video Memory - Shared system memory
Memory
Memory - 1GB
Hard Drive
HDD - 160GB
Hard Drive Spec - +10GB Internet Storage
Dimension & Weight
Dimension - 10.47" x 7.53" x 1.12-1.5"
Weight - 3.2 lbs.
Feature
Feature:
- Easy to Learn, Work, and Play
- 7 hour battery life allows for "One Day Computing"
- Travel light, weighting only 3.20lbs
- Wireless 802.11b/g connectivity
- Connect with friend with built-in Camera
- XP Home, MS Works, and Windows Live preloaded
- Wide Touchpad for comfort and convenient
- Glossy IMR Pearl White color for elegant look
- ZBD Guaranteed for best quality LCD
- Protect your investment with sleeve case
Netbook Camera
Camera Type - Built-in
Camera Pixels - 1.3 Megapixel
Communications
LAN - 10/100Mbps
WLAN - 802.11b/g Wireless LAN
Expansion / Connectivity
USB - 3
Video Ports - 1 x VGA
Audio Ports - 1 x Microphone jack; 1 x Headphone jack
Audio
Audio:
- Hi-Definition Audio CODEC
- Digital Array Mic
Speaker - Built-in stereo speakers
Input Device
Touchpad - Yes
Keyboard - Standard
Card Reader
Card Reader - MMC/SD(SDHC)
Power
AC Adapter:
- AC Adapter Output: 12V, 36W
- AC Adapter Input: 100-240V AC, 50-60Hz universal
Battery
Battery - 6-cell lithium ion
Battery Life - 7 hours
Manufacturer Warranty
Labor - 1 year limited
Parts - 1 year limited
Re: Computer Specs
Postby JAHGoVeg » Tue Nov 30, 2010 1:28 am
SUMMARY
-Computer-
Processor : Genuine Intel(R) CPU U2700 @ 1.30GHz
Memory : 3025MB (743MB used)
Operating System : Linux Mint 10 Julia
-Display-
Resolution : 1366x768 pixels
OpenGL Renderer : Mesa DRI Mobile Intel® GM45 Express Chipset GEM 20100330 DEVELOPMENT x86/MMX/SSE2
X11 Vendor : The X.Org Foundation
-Multimedia-
Audio Adapter : HDA-Intel - HDA Intel
Processor
Name : Genuine Intel(R) CPU U2700 @ 1.30GHz
Family, model, stepping : 6, 23, 10 (Pentium III/Pentium III Xeon/Celeron)
Vendor : Intel
-Configuration-
Cache Size : 2048kb
Frequency : 1300.00MHz
BogoMIPS : 2593.91
Byte Order : Little Endian
-Features-
FDIV Bug : no
HLT Bug : no
F00F Bug : no
Coma Bug : no
Has FPU : yes
-Cache-
Level 1 (Data) : 8-way set-associative, 64 sets, 32KB size
Level 1 (Instruction) : 8-way set-associative, 64 sets, 32KB size
Level 2 (Unified) : 8-way set-associative, 4096 sets, 2048KB size
-CPU Blowfish-
This Machine 1300 MHz 41.394
Intel(R) Celeron(R) M processor 1.50GHz (null) 26.1876862
PowerPC 740/750 (280.00MHz) (null) 172.816713
Re: Computer Specs
Postby Guest » Tue Nov 30, 2010 8:43 pm
Thats a weird resolution JAHGoVeg
Re: laptop Specs
Postby gamfrkI » Sat Sep 10, 2011 5:13 am
OS:MS Windows 7 Ultimate 64-bit SP1 and soon ubuntu
CPU:Intel Core i7 4 cores
RAM:4 gb ddr3
GPU:ATI FirePro M7820,DirectX Support 11.0,OpenGL Support 5.0,Video RAM 2.7 GB,Shader version 5.0 ,Vertex Shader version 5.0
HD:toshiba 488 gb
misc:dvd burner,Bluetooth Hands-free Audio,ATI High Definition Audio Device,IDT High Definition Audio CODEC
Re: Computer Specs
Postby The Shadow Dragon » Thu Sep 15, 2011 3:33 am
System Info:
ASUS Notebook U52F Series
4GB DDR3 RAM
Intel Core i3 CPU M 380 @ 2.53GHz
640GB HDD
DVD RW Drive
Most of this information came straight from the System Info from the Control Panel. Runs pretty much anything I can throw at it (not at full graphics settings though.)
Steam: PirateBear
The Shadow Dragon
Has thanked: 9 times
Been thanked: 15 times
Fav System: Dreamcast
Users browsing this forum: No registered users and 43 guests
