HOWTO | Softmodding a Wii
Re: HOWTO | Softmodding a Wii
Postby paddypatch » Mon Sep 22, 2014 7:37 pm
Hi
I have got 2 X wii
1. Is modded and it loads roms from a usb hdd
2. Was not modded when I was given it
I downloaded everything I needed to softmod it myself.
I hve never done anything like this before.
I used hackmii_installer_v1.2 ( wii load boot.elf boot mini.elf )
some file called aad1f_v108 ( files on sd card )
all files I download where on my previous laptop
which was stolen with other thing from my home.
As far as I know by reading the txt document which I printed out
I have Installed the HBC and bannerbomb etc installed BootMii
The end of the txt document says delete bannerbomb of sd card
I remember doing all this.
The the txt says that's it depending what you want to do.
However If you want more like back up loading custom themes etc
you will need to continue below......as I don't have my old laptop and files
should I just follow the instructions above to part 2 of the guide.
Thank you all in advance
Paddypatch
Just like to say :thankyou: to all the above
for having a really :goodpost:
its been a very good read.
I might just have a look at the other guides
to modding other consoles.
thanks again
paddypatch
Previous
Users browsing this forum: No registered users and 11 guests
