retro cores made in china emulation box review -the LDK
Postby nightshade » Sat Jul 20, 2019 3:27 am
This one looks way better than last weeks and theres custom firmware for it all ready ..... apparently theres also a landscape version thats even better
"theres no point it telling me the wisdom of a fool cant and wont set me free"-new order
"its always easier and usually better to get forgiveness than permission"-various
nightshade
Next LVL Up at : 170
Has thanked: 19 times
Been thanked: 55 times
Fav System: all systems
Re: retro cores made in china emulation box review -the LDK
Postby nightshade » Sat Jul 20, 2019 3:36 am
heres a review by someone else of the landscape version its pretty much the same he just uses custom firmware .....
nightshade
Postby Hot Trout » Mon Jul 22, 2019 10:55 am
Thanks for posting these. Which would you choose. The pocket go? I like the layout of the new LDK and it seems like a solid choice for emulation on the go.
Next LVL Up at : 3650
Has thanked: 2233 times
Been thanked: 1954 times
Postby nightshade » Sat Aug 03, 2019 4:38 am
heres an update with the custom firmware
nightshade
Postby gehlotsur » Fri Oct 07, 2022 10:23 am
Heads up: the screen bezel is plastic and will scratch. There are glass screen protectors available on Aliexpress and I highly recommend them. I also recommend installing the custom firmware, RetroFW. It's nicer to use and improves performance on some emulators.
gehlotsur
Fav System: Windows 11
Users browsing this forum: No registered users and 80 guests
