install it to my new Xbox 360
Postby juvaliya » Wed Feb 19, 2014 12:42 pm
I bought my Xbox 360. When it came out first it’s been working great, but it finally was giving up. My games just constantly started freezing a lot. I don't mind purchasing another Xbox 360, but the problem is I don't want to loose all of my memory. So can I remove my hard drive from my messed up Xbox 360 and install it to my new Xbox 360 and it will have all the stuff it had on the old Xbox 360?
__________________________
No Advertising allowed
juvaliya
Re: install it to my new Xbox 360
Postby Kherr » Mon Jun 30, 2014 5:03 am
It depends on the model of Xbox 360. If you have a normal Xbox 360, then that cable that HARDY mentioned will be the tool you want. If you have a Xbox 360s then you can just remove the HDD from the messed up 360s and slide it into your new Xbox 360s. :hi:
Return to Modern Consoles
Users browsing this forum: No registered users and 6 guests
