Think About Mame4droid for update 0.139 to later version
Postby vus7294 » Thu Jun 04, 2015 8:36 am
First, i have bad english. sorry
is it possible to request update MAME4dorid version?
I mean, MAME4droid Version is Only for 0.139u1 for present. And 0.37b11 version called iMAME4all.
iMAME4all is optimized for a low spec android and ios.
But higher Spec android. i want to request update mame4droid version to 0.154(because Raiden 2 and dx and zero team seibu cup eolith game and some igs pgm game cave sh3 ETC)
retroarch has mame later emulator but some games i want to play are not working.
i have question again. is it possible to request update MAME4droid version?
vus7294
Fav System: Emulator for Android
Re: Think About Mame4droid for update 0.139 to later version
Postby Hot Trout » Thu Jun 04, 2015 1:53 pm
I I understand you correctly, you want the latest versions of the Mame4Droid emulator added to the website, yes?
Next LVL Up at : 3650
Has thanked: 2233 times
Been thanked: 1954 times
Postby vus7294 » Thu Jun 04, 2015 2:21 pm
Hot Trout wrote:I I understand you correctly, you want the latest versions of the Mame4Droid emulator added to the website, yes?
MAME4droid Reloaded is only 0.139. newer version is only bug fix and some more. so i will request mail to based later MAME(like 0.154) for Higher spec android phone.
vus7294
Postby Hot Trout » Thu Jun 04, 2015 6:44 pm
Which romsets of MAME does the later version use?
Postby vus7294 » Sat Jun 06, 2015 5:09 am
Hot Trout wrote:Which romsets of MAME does the later version use?
No. i mean. mame4droid's newest(later) version is only 0.139. just same as first version. i mean i will request seleuco directly for gmail.
vus7294
Users browsing this forum: No registered users and 9 guests
